Her's a video of the first open field test. The only real problem I can see is that at speed or in a headwind, the pitch motor on the gimbal just cant take it. You can see start to show in the video but bear in mind that this was flown entirely in stable mode so throttle was capped at 70%.
Next to build a stranger gimbal.
