Hackaday.io Hackaday.io
Sign up Log in
LightFox Dual - esp8266+RF dual channel switch
Making low power dual channel remote switch for lights.
andrey-kupreychikAndrey Kupreychik
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2k views
0 comments
1.4k followers
  • Description
  • Details
  • Files 0
  • Components 14
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
2k
0
1.4k
12
Team (1)
  • andrey-kupreychikAndrey Kupreychik
Join this project's team
  • sources
  • firmware
hardware
ongoing project
ESP8266 remote Tasmota
This project was created on 01/23/2018 and last updated 3 years ago.
Description
Goals:
* small footprint to place under chandelier base
* WI-FI control from home automation hub
* RF control from 433 MHz remotes
* dual channel
Components
  • 1 × Itead.cc RF Receiver Module-433Mhz https://www.itead.cc/rf-receiver-module-433mhz.html
  • 1 × ESP-01S module https://www.aliexpress.com/item/DIY-ESP8266-ESP-01S-Wireless-Wifi-Sensor-for-Arduino-ESP-01-Advanced-Version-wireless-transceiver/32769396676.html?spm=a2g0s.9042311.0.0.0tJMnX
  • 1 × HLK-PM03 AC-DC 220V to 3.3V https://www.aliexpress.com/item/HLK-PM03-AC-DC-220V-to-3-3V-Step-Down-Buck-Isolated-Power-Supply-Module/32834028942.html?spm=a2g0s.9042311.0.0.E6KVx4
  • 1 × Atmel ATTINY441-SSU
  • 2 × 470 Ohm 0.5W resistor
View all 14 components
Project Logs
Collapse
  • ESPurna firmware
    Andrey Kupreychik • 01/04/2019 at 14:24 • 0 comments
    Hi all!
    After researching thru ESP modules firmware options I found a better option of the firmware for the switch. It's ESPurna firmware. The main advantages I see in ESPurna are: compile-time module definition and async MQTT.
    Currently ESPurna firmware for LightFox dual is tested on my instances. It works OK. The firmware is available for download on github: https://github.com/foxel/esp-dual-rf-switch/blob/v3/esp01-firmware/espurna-1.13.4-dev-foxel-lightfox-dual.bin
  • Updating to V3. Pushing to Tasmota
    Andrey Kupreychik • 08/27/2018 at 03:40 • 0 comments
    Long time no see guys.
    The best news for the project is that it got to stable version tested and deployed :) Bad news later.
  • Firmware is ready, project is on github
    Andrey Kupreychik • 03/09/2018 at 14:32 • 0 comments
    First fimware is ready to be used.
    Was trying to use attiny44 instead of 441 for a week but failed with software UART timings.
    Then received 441 which was initially planned and UART worked like a charm.
    The firmware is split in two parts: ESP8266 firmware and Attiny441 firware.
    For ESP8266 part i've decided to fork Sonoff-Tasmota and use Sonoff DUAL UART protocol for controllers communication. For attiny i've designed firmware by myself.
    Currently the main use-case is covered and I can control channels from RF and MQTT. Still need to address RF binding/cleaning by triggering button from attiny.
    Also the project is now available on GitHub: https://github.com/foxel/esp-dual-rf-switch
    And finally demo:
  • I've got PCBs... and assembled first switch
    Andrey Kupreychik • 02/17/2018 at 18:06 • 0 comments
    So I recently received PCBs from jlcpcb.com. It cost me about $8 including delivery. Pretty cheap I think.
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
Official Hackaday Prize Entry
General purpose low cost handheld terminal with screen/kbd, wifi, barcode and RFID reader for industrial or commercial (or any other) use
Project Owner Contributor
Data Collection Terminal
bozBoz
The 2015 Hackaday Prize
Make Weloop Tommy an open source sport watch that can connect directly to all kind of sensors (heart rate monitor and so on)
Open source sport/smart watch
krzysiekKrzysiek
Home automation using the Loxone series of home automation products along with hacks to extend functionality and reduce cost
Commercial home automation
ian-nortonIan Norton
Updating the original HC-12 with a CH32V003
A Risc-V HC-12 433Mhz Serial Bridge
ozqubeOzQube
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "LightFox Dual - esp8266+RF dual channel switch", please tell us the reason.
Send message
Remove Member
