This is the first design of the mounting plate for the back of the clockhouse. Black stuff will be engraved, red stuff will be cut. I don't know if i take brass or acrylic. Acrillig could be cool with RGB Leds...
On 24/01/2015 the clock housings will be delivered. Drawing first sketches for the internal hardware-mounting. Probably i will use laser cutted brass. So i need to find a good laser-cutter service company in germany...
