Arduino Sketch
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary • 10/12/2014 at 00:30•0 Comments
Here is the Arduino Sketch. Nothing fancy. It is a mix of my code, code fragments from other peoples projects as well as vendor sample code.
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xee
IPAddress ip(192, 168, 1, 178);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
float current_input_value = 0; // value read from the carrier board
float amps = 0;
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
void loop() {
float voltage;
float watts;
char buffer[10];
String S_label ;
String S_voltage ;
String S_amps ;
String S_watts ;
String S_print = S_label + S_voltage + S_amps + S_watts;
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
//get the volatage
voltage=get_voltage(A0); //get volatge on A0
//Get the Current
current_input_value = analogRead(A1);
amps = float ((((long)current_input_value * 5000 / 1024) - 500 ) * 1000 / 133)/1000;
if (amps < 0 )
amps = 0 ; // Get rid of sensor noise when currentt is at/near zero.
watts=(amps * voltage);
S_label = "Panel" ;
S_voltage = dtostrf(voltage, 2,2, buffer );
S_amps = dtostrf(amps, 2,2, buffer );
S_watts = dtostrf(watts, 2,2, buffer );
S_print = S_label + " " + S_voltage + " " + S_amps + " " + S_watts;
client.println (S_print);
client.println ("<br>");
//get the volatage
voltage=get_voltage(A2); //get volatge on A5
//Get the Current
current_input_value = analogRead(A3);
if (amps < 0 )
watts=(amps * voltage) ;
S_label = "Battery" ;
//get the volatage
voltage=get_voltage(A4); //get volatge on A5
//Get the Current
current_input_value = analogRead(A5);
if (amps < 0 )
S_label = "Load" ;
client.println("</html>");
break;
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
float get_voltage ( int vpin ) {
float gvolt=(analogRead(vpin)/4.092)/10;
return gvolt;
