Network interface
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary 04/03/2014 at 00:430 Comments
I originally had planned to use a w5100 ethernet shield, but  the shield  ended up using A0-A4... By moving to the non-shield module I now have access to all the analog ports on my arduino.
