Field testing
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary 05/26/2014 at 20:130 Comments
I wanted to see how the hardware and code worked connected to something other than the bench supply I had been testing on.  I put the arduino, network and proto shield into a cheap plastic case. $1.99 for 10 small "project" cases from the local grocery store.
I connected the arduino between the solar panels and the charger controller to get a reading from the panels.
