Board work
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary • 06/20/2014 at 21:10•0 Comments
Spent some time today working on the monitoring board.. Power pole connectors attached to current sensors.
I used 12 gauge wire for the connections but 14 gauge would have worked as well and been easier to use.
