Testing voltage modules
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary • 03/16/2014 at 20:46•0 Comments
Here is the test setup for  the voltage testing. A simple voltage divider network and  sketch to look at an analog pin.
