Messing around with a TPlinkMR3020, Adafruits Powerboost 500 and a Battery all stuffed in a handy container. Battery runs about 5 hours with low use. I need to test it with several active connections sucking down files.
A project log for Anyfesto
Any manifestation of a meeting - in the schools or in the streets - is going to need clear communication. Anyfesto helps that happen.
