Winter time means some free time to look back over things and see what needs doing. The PIFold Project has a more detailed post about this push but the short version is Anyfesto needs a good code clean up, a set of install scripts to make it easier to install in PI, PI0 and CHIP as well as some much needed reworking of bodges that at the time worked great but now are stumbling blocks for new users.
If you have aby suggestions along these lines or idea for Anyfesto please post them up here.
Here now is a pic of the CHIP based Anyfesto build that has been in my go bag for the last few months. It is a rock solid bit of gear that shows some of the PROs in using the CHIP over the PI's ; built in battery charging circuit, wifi and bluetooth being the big items.
