After getting the CHIP side of the house stable I spent some time over the last month working on the PI installs, both manual and scripted. Now it needs some else's eyes and hardware other than my own to test things out and report the bugs.
If you have the time and a Pi hanging around please head on over to
https://github.com/tomhiggins/anyfesto/blob/master/installPI
and see if thing work or if they break bad.
The next phase after this will be a clean up and a proper release most anyone can use to get one of these up and running.
After that? I want to create a few specialized builds to address Education, Privacy and Social Gatherings. Each one will be be an easy to run script that will install not only the services/apps but all the content needed to address those issues. The EducationBox will be my first priority.
So break and report and we can get that much closer to the goal.
Thanks in advance
