Y Axis Mechanical Test
A project log for 3D Printer
Attempt to dive into 3D printing
willbadenwillbaden 01/31/2015 at 11:412 Comments
Before I could dedicate myself to using the selected scanner bed for the Y axis, I wanted to verify that the motor and mechanism was going to work. Here is a test of the Y axis.
This proved it out, now to change the layout of the bed. Currently the bed can flop around up and down and slide for side to side perpendicular to the axis movement. This should be able to be remedied by using bearings on the top and the bottom of the bearing track to capture any vertical movement. And also adding bearings to press up against the side walls to prevent side to side movement.
Rich text editor
Saabman wrote 02/03/2015 at 23:58 point
excellent work.
Perhaps adding a print head and linear bearing and shaft from a bubble jet (just along one edge) might be all you would need to stabilize it.
willbaden wrote 02/04/2015 at 00:15 point
That is a great idea. I have already started on an aluminum carriage utilizing the already bearing surface available. I will try to post a new log tonight even if I do not complete the carriage.
