One of the nice things about the Arduino Yun is that you can just plug it in anywhere, and still access it via wifi. So, in it goes, and connected to the garage door button.
Here you can see the relay connected to the garage door button that is plugged into the power strip.
My door switch sensor is still in "test mode", hanging down under the red breadboard. That will be this weekend's task.
Pete Hoffswell
