Code dump:
El Radio
Written by Jeremy Lambert
Copyright 2015 All Rights Reserved
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
#include "TFTLCD.h"
#include "TouchScreen.h"
#if not defined USE_ADAFRUIT_SHIELD_PINOUT
#error "For use with the shield, make sure to #define USE_ADAFRUIT_SHIELD_PINOUT in the TFTLCD.h library file"
#endif
// These are the pins for the shield!
#define YP A1 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 7 // can be a digital pin
#define XP 6 // can be a digital pin
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
#define MINPRESSURE 10
#define MAXPRESSURE 1000
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, 0);
#define BOXSIZE 80
String inputString = ""; // a string to hold incoming data
boolean stringComplete = false; // whether the string is complete
void setup(void) {
//Serial.println("TOUCHSCREEN::");
tft.reset();
uint16_t identifier = tft.readRegister(0x0);
if (identifier == 0x9325) {
//Serial.println("Found ILI9325");
} else if (identifier == 0x9328) {
//Serial.println("Found ILI9328");
} else {
//Serial.print("Unknown driver chip ");
//Serial.println(identifier, HEX);
while (1);
tft.initDisplay();
tft.fillScreen(BLACK);
DrawButtons();
delay(5000); //let the BT module boot
inputString.reserve(12);
Serial.begin(115200);
Serial.println("CMD"); //enter command mode.
delay(300);
Serial.println("B"); //try to reconnect to the last device
pinMode(13, OUTPUT);
void serialEvent()
while (Serial.available())
// get the new byte:
char inChar = (char)Serial.read();
// add it to the inputString:
inputString += inChar;
// if the incoming character is a newline, set a flag
// so the main loop can do something about it:
if (inChar == '\n')
if (!inputString.startsWith("AOK"))
stringComplete = true;
char output[inputString.length()];
//Serial.println(inputString);
inputString.toCharArray(output, inputString.length());
tft.drawString(0,0,output, WHITE, 2); //TODO: need to put this somewhere else on the screen.
void loop()
digitalWrite(13, HIGH);
Point p = ts.getPoint();
digitalWrite(13, LOW);
// if you're sharing pins, you'll need to fix the directions of the touchscreen pins!
//pinMode(XP, OUTPUT);
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
//pinMode(YM, OUTPUT);
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
if (p.z > MINPRESSURE && p.z < MAXPRESSURE)
// turn from 0->1023 to tft.width
p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
p.y = map(p.y, TS_MINY, TS_MAXY, tft.height(), 0);
Serial.print("("); Serial.print(p.x);
Serial.print(", "); Serial.print(p.y);
Serial.println(")");
if (p.x < BOXSIZE)
if (p.y > 240)
//rewind
Serial.println("AT-");
blinkButton(0);
return;
if (p.y > 80)
//volume -
Serial.println("AV-");
blinkButton(4);
return;
if (p.y > 0)
//volume +
Serial.println("AV+");
blinkButton(3);
return;
if (p.x < BOXSIZE*2)
if (p.y > 240)
//play/pause
Serial.println("AP");
blinkButton(1);
return;
if (p.x < BOXSIZE*3)
if (p.y > 240)
//ff
Serial.println("AT+");
blinkButton(2);
return;
//spare
//spare
if (p.y > 0)
//if you push the bluetooth button, it goes to discoverable, since it's default
//is attempt reconnect.
Serial.println("@,1");
blinkButton(5);
return;
void drawButton(int buttonID)
switch(buttonID)
case 0: //rewind
tft.fillRect(0, 240, BOXSIZE, BOXSIZE, BLACK);
tft.drawRect(0, 240, BOXSIZE, BOXSIZE, WHITE);
tft.drawString(20, 270, "<<", WHITE, 3);
break;
case 1: //playpause
tft.fillRect(BOXSIZE, 240, BOXSIZE, BOXSIZE, BLACK);
tft.drawRect(BOXSIZE, 240, BOXSIZE, BOXSIZE, WHITE);
tft.drawString(95, 270, "||>", WHITE, 3);
break;
case 2: //ffwd
tft.fillRect(BOXSIZE*2, 240, BOXSIZE, BOXSIZE, BLACK);
tft.drawRect(BOXSIZE*2, 240, BOXSIZE, BOXSIZE, WHITE);
tft.drawString(180, 270, ">>", WHITE, 3);
break;
case 3: //volumeup
tft.fillRect(0, 0, BOXSIZE, BOXSIZE, BLACK);
tft.drawRect(0, 0, BOXSIZE, BOXSIZE, WHITE);
//tft.drawString(35, 35, "^", WHITE, 4);
tft.drawTriangle(40, 22, 53, 56, 26, 56, GREEN);
tft.drawTriangle(40, 24, 53, 58, 26, 58, GREEN);
break;
case 4: //volumedown
tft.fillRect(0, 80, BOXSIZE, BOXSIZE, BLACK);
tft.drawRect(0, 80, BOXSIZE, BOXSIZE, WHITE);
//tft.drawString(35, 100, "v", WHITE, 3);
tft.drawTriangle(26,101,53,101,40,135,GREEN);
tft.drawTriangle(26,103,53,103,40,137,GREEN);
break;
case 5: //BLUETOOTH
tft.fillRect(160, 0, BOXSIZE, BOXSIZE, BLACK);
tft.drawRect(160, 0, BOXSIZE, BOXSIZE, WHITE);
//tft.drawString(180, 30, "BT", WHITE, 3);
tft.drawLine(182, 10, 182, 70, BLUE);
tft.drawLine(182, 10, 200, 25, BLUE);
tft.drawLine(200,25, 182, 40, BLUE);
tft.drawLine(200, 51, 182, 40, BLUE);
tft.drawLine(182, 70, 200, 51, BLUE);
break;
void blinkButton(int buttonID)
switch(buttonID)
case 0:
tft.fillRect(0, 240, BOXSIZE, BOXSIZE, WHITE);
tft.drawString(20, 270, "<<", BLACK, 3);
break;
case 1:
tft.fillRect(BOXSIZE, 240, BOXSIZE, BOXSIZE, WHITE);
tft.drawString(95, 270, "||>", BLACK, 3);
break;
case 2:
tft.fillRect(BOXSIZE*2, 240, BOXSIZE, BOXSIZE, WHITE);
tft.drawString(180, 270, ">>", BLACK, 3);
break;
case 3: //volumeup
tft.fillRect(0, 0, BOXSIZE, BOXSIZE, WHITE);
tft.drawTriangle(40, 22, 53, 56, 26, 56, RED);
tft.drawTriangle(40, 24, 53, 58, 26, 58, RED);
break;
tft.fillRect(0, 80, BOXSIZE, BOXSIZE, WHITE);
tft.drawTriangle(26,101,53,101,40,135,RED);
tft.drawTriangle(26,103,53,103,40,137,RED);
break;
case 5: //BLUETOOTH
tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, WHITE);
//tft.drawString(BOXSIZE*2 + 20, 30, "BT", BLACK, 3);
tft.drawLine(182, 10, 182, 70, RED);
tft.drawLine(182, 10, 200, 25, RED);
tft.drawLine(200,25, 182, 40, RED);
tft.drawLine(200, 51, 182, 40, RED);
tft.drawLine(182, 70, 200, 51, RED);
break;
delay(100);
drawButton(buttonID);
void DrawButtons()
for(int i=0; i < 6; i++)
drawButton(i);
tft.drawString(25, 165, "VOL", GREEN, 2);
