Hackaday.io Hackaday.io
Sign up Log in
Clean water for Africa
A solar powered system for filtering and Ozone disinfecting rural water supplies for communities
paul-scottPaul Scott
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
6 comments
37 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 6
View Gallery
1.6k
6
37
13
Team (1)
  • paul-scottPaul Scott
Join this project's team
hardware
ongoing project
community water rural ozone purification disease saving the planet upliftment
This project was created on 01/24/2015 and last updated 11 years ago.
Description
Using a combination of traditional water filtration methods, as well as generating purifying ozone via a solar source, water from just about any source can be turned into potable water for use in cleaning, cooking and drinking.
In Africa, especially, there are more than 350 million people, and over 750 million people around the world, with no access to clean water. Additionally, over 840 000 people die each year from water borne infections and disease.
This is, of course, highly preventable, but as water purification set ups are generally very expensive, and require large amounts of electricity to operate, I have decided to go a little lower tech, whilst still providing the highest quality water possible.
There should be very few moving parts, or complex electronics, to ensure that the units can be easily maintained by the community itself.
Project Logs
Collapse
  • Photo credit
    Paul Scott • 01/24/2015 at 13:49 • 3 comments
    Thanks
    to
    http://i.huffpost.com/gen/1292684/thumbs/o-CLEAN-DRINKING-WATER-AFRICA-facebook.jpg
    for the initial image. I am just borrowing it, as my wife is a pro photographer, and should supply me with images soon!
View project log
Log In/Sign up to comment
Sign up with Github
OR
Polymath8 wrote 04/10/2025 at 05:09 • point
This is excellent! I am working on a similar project myself as well. a looping system with easily sourced parts. Feel free to check out my Github repository. open source, DIY
higorsantiago wrote 08/02/2022 at 11:11 • point
There are some very amazing things that you can check here on the wet wash house cleaning service where they have added the similar ideas in  their project.
menopausetea2020 wrote 07/08/2020 at 23:21 • point
This post is great 100%! If your looking for a trusted herbal tea, please check this website www.menopauset.com
mr.jb wrote 08/19/2015 at 05:16 • point
Biosand
http://www.cawst.org/resources/biosand-filter
UV light ....( natural ) and/or powered by solar cell
Active carbon to remove chemicals....
In some areas collecting water from the fog might be the best ...
https://www.allianz.com/en/about_us/open-knowledge/topics/environment/articles/110304-collecting-drinking-water-from-fog.html/
Paul Scott wrote 08/19/2015 at 11:42 • point
I have been experimenting with Ozone as well as UV light, after using a filtration system and then the activated charcoal filter method as on the biosand site that you posted. Ozone is good, but not great for potential accidents/leakages. Will look more into the UV systems though too.
Good thing about an ozone generator, is that you can make one in about 15 minutes... UV II suspect would take longer, and getting replacement lamps into the field may be problematic.
Mike Szczys wrote 05/29/2015 at 19:41 • point
This should totally be a Hackaday Prize entry!
A low-cost, solar-driven method of water purification for the developing (and developed!) world.
Project Owner Contributor
Vacuum Water Purification
ben-nitkinBen Nitkin
Energy Efficent Water Smart Filters sold philanthropically to address Water Crisis in Flint and America at large
Potable
jfolksjfolks
A distributed sensing system for managing water resources in informal communities. It monitors water quality, quantity and use within homes.
Axol
andres-ricoAndres Rico
The 2016 Hackaday Prize
Using Diatoms and Graphene clean fresh water can be produced from sea water, or contaminated aquifer's.
Graphene & Diatom Desalination of Water
mechanicusMECHANICUS
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Clean water for Africa", please tell us the reason.
Send message
Remove Member
