24/01/2015
Done :
The warning system is implemented and working
To do :
Correct software bugs
Troubleshoot the battery voltage monitoring
Upload code examples
Upload PCB schematics and layout
New PCB
- add capacitors next to the Module
-change the SIM card slot location (the sma connector is blocking the slot)
-new battery watching interface
-improve component placement
Hey
That's not really challenging if you already have some electronic design skills. Simcom the company that sells the GSM module provides guidelines on their "Hardware design Guide". The software is really simple it's all python scripts on top of Linux.
I have a new PCB version currently being manufactured, I plan to publish all the design files as well as the software soon !
