7075 Aluminium cnc milled scales of a Swisschamp or alike, circuitry on left side and accessories stored on the other scale and belt clip. Current version is based on Arduino, pcb flex, powered by a small Lipo with oled 128 x 32, low power Bluetooth, PMIC, micro SD, nav trackpad, sensors and a multipurpose 4 pin jack for interch. devices like: USB charger, flash light, laser pointer, tachometer and tools like a small dc soldering iron, scope probe, and ac/dc clamp meter. Mech. mods for electronic techie tool: Magnet on the pliers spring. Add a small diamond disc on pliers handle to be used as glass cutter. Punch rod in the hook gap and a soldering wire dispenser under screwdriver. The storage scale drawer, should accommodate the micro soldering iron, the probe, fuse wire, ferro rod, tiny sachets with crazy glue, Conduct. ink, isoprop. alcohol and wick for cleaning/fire. Plans to upgrade to a Samsung ARTIK 1 Module.
Details
Accessories:
Soldering iron
Laser Pointer / Flashlight / light sensor
Soldering wire dispenser
Probe
Micro SD card reader / charger / hook on belt clip
there is something about this design that I totally love, maybe just a MacGyver thing... your design is something between a sonic screwdriver and a swiss army knife, great!
