Github with Netduino code to read the MODE PWM pin's measurements.
A project log for 360 Degree LIDAR-Lite Scanner
I took two LIDAR-Lite laser range finders and mounted them atop a 3D printed, 360 degree continuously rotating frame, to scan any area.
