Hi, after a long time I update the project:
- New class files.
- New MPLABX project
- ADC, SPI, LED demo, the SPI demo was made to use the MCP3021 ADC from mcirochip
- Debug project, well really isn't a debug itself, is an application that have an space to retrieve 10 SFR values selected from combo box and a space to make your own test application.
All the methods are xml documented, so while you type the method data about it will apear. GPIO, ADC, SPI, I2C, PWM and analog comparator was tested and work OK, USART Synchronous and Asynchronous are tested to work (using logic analyzer) but I need to test with something that can reply I will do some code and a 16F628 to test USART, Voltage reference module isn't tested but today will do that.
Finishing with USART I will start with JTAG and the UDF (User Defined Functions) that I mentioned the last log.
