The layout of the board is finished, I can't upload it right now because I got that on a different PC. The only thing I'm missing (which is also missing from the original schematic) is correcting the output voltage of the sync lines to a proper TV-acceptable signal. Any suggestion? I'm posting this on the stack as well.
