Knocked this up last night from plasticard and spare bits
servo is a HK15138 3.8Kg-cm servo from hobbyking (£2.22)
calculated exerting 5.4Kg at start of travel building to technically infinite at end of travel, either way, plenty of force to clamp the tube properly. bolts used for easy adjustment.
This is an interesting idea. We're using solinoid valves that are about the same price for our project. http://www.ebay.com/itm/1-4-NPT-Electric-Solenoid-Valve-12-Volt-DC-12VDC-N-C-RO-Air-WaterBBTF-12pk-/272050889127?hash=item3f577f21a7
