First power-up of the Third Proto-type
A project log for Smart Switch
A 125 volt 15 amp dimmer switch with built-in 5 volt power supply, current monitoring, and programmable micro-controller.
karl-edlerKarl Edler • 04/19/2015 at 03:35•0 Comments
The goal now is to make a fully functional smart-switch in its final mechanical form. Below is a picture of the electronics and the 3D printed shields. The electronics have not yet been programmed with the firmware from the 2nd proto-type but it is producing 5V from the AC mains.
The 3D printed plastic bits do not fit very well yet so the electronics are wrapped in electrical tape.
