Razer Orochi Lithium Upgrade
Added rechargable lithium to razer orochi bluetooth gaming mouse
Added a lithium polymer and lithium charger board into my razer orochi bluetooth gaming mouse so i didnt need to use 2 AA batteries anymore. The existing micro usb port is tapped into for power to the charger and has a switch to change between a full usb mouse or bluetooth mouse. total project time was just under an hour.
  • 1 × 1A MICRO USB LITHIUM CHARGING BOARD
  • 1 × 300 MAH LITHIUM BATTERY
  • 1 × 32 AWG SILVER PLATED TEFLON WIRE
  • 4 × MICRO DEANS CONNECTORS
thp777 wrote 04/18/2015 at 18:56 • point
i attached it to where the battery connects on the mainboard because when power is applied thru the built in usb it tries to turn on the usb part of chip and turn off bluetooth. i can make up a wiring diagram. ive taken this apart recently as im putting the board from this and a steelseries free controller inside a logitech g600 casing
guillaume wrote 04/19/2015 at 12:11 • point
Yes if you could post either a picture or a diagram it’d be great.
Thx I think I understood where to solder it
guillaume wrote 04/18/2015 at 09:53 • point
Hi I really like your project and I’d like to mod my mouse as you did.
Do you need to unplug the lithium charging board every time you switch from charge to use?
Thanks
thp777 wrote 04/18/2015 at 16:20 • point
one part of board connects to power and one part connects to battery so you do not have to take it out to charge.
guillaume wrote 04/18/2015 at 16:32 • point
Would it be possible to have schematics or something like that to know exactly where I have to solder the wires within the mouse?
If you don’t have anything like that don’t mind
If I have correctly understood I just have to solder the lithium charging board to the inner part of the female micro-usb then the lithium battery, and that's all ??
Thank you for your quick reply
