I've started working on a few parts already, before I decided to create this log. I'll start by listing the components that have already been established:
M.NT68676.2A (LCD controller board) see: Specifications sheet (PDF Warning)
17.3" 1600x900 LVDS LCD panel from HP G72 Laptop, part number: LP173WD1
High-Res shot of LCD controller.
Mounting bolts installed, careful not to make contact with any traces.
So the thought process now is, do I keep the LCD in the lid of the laptop (sans base-as it stands currently) or make a custom enclosure with other goodies stuffed inside? Something else?
