A breadboard adapter for ESP-07 and ESP-12 ESP8266 WiFi module. It contains a 3.3V voltage regulator, a Reset/Program button and a UART connector with FTDI Basic compatible pinout.
Details
I build this ESP8266 breakout board because I love the ESP-07/12 WiFi modules. However they come with 2.0mm pitch connectors that are very hard to work with. So I designed a breakout board. My design goals are:
Can you describe how your easy program / reset circuit works?
