Updated Rotary Encoder Menu
I updated the Rotary Encoder menu for the LCD display:
// Include LCD library and initialise
#include <LiquidCrystal.h>
// Define Adruino pin numbers for LCD
#define en 7
#define rs 8
#define d4 9
#define d5 10
#define d6 11
#define d7 12
#define led 13
// Set LCD
LiquidCrystal lcd(rs,en,d4,d5,d6,d7);
/* ROTARY ENCODER AND PUSH BUTTON POLLING CODE */
#define Clk 2
#define DT 3
#define SW 4
// Poll and debounces a Keyes rotary and push button switch
// Inputs:
// Clk (Pin A with 10k pullup resistor)
// DT (Pin B with 10k pullup resistor)
// SW (Switch without a pullup resistor)
// + (Power for pullup resistors)
// Gnd
// Exports:
// UpdateSwitch (bool) [true|false]
// Switch (byte) [LOW|HIGH]
// EncoderPos (char) [-128..127]
volatile bool UpdateSwitch=false;
volatile byte Switch=HIGH;
volatile char EncoderPos=0;
ISR(TIMER0_COMPB_vect) {
static byte testClk=(PIND>>Clk)&1;
static byte testDT=(PIND>>DT)&1;
static byte lastClk=LOW;
static byte lastDT=LOW;
static bool flagClk=false;
static bool flagDT=false;
static char encoderDir=0;
static byte testSW=HIGH;
static byte statusSW=HIGH;
static byte cntSW=0;
// Update Encoder Position
lastClk=testClk; // Save Clk
lastDT=testDT; // Save DT
testClk=(PIND>>Clk)&1; // Get Clk
testDT=(PIND>>DT)&1; // Get DT
if (testClk!=lastClk) { // Change in Clk?
flagClk=true; // Flag Clk has changed
encoderDir=-1; // Assume it is the last flag to change
if (testDT!=lastDT) { // Change in DT?
flagDT=true; // Flag DT has changed
encoderDir=1; // Assume it is the last flag to change
if (flagClk&&flagDT) { // Both flags have changed
EncoderPos+=encoderDir; // Update the encoder
flagClk=false; // Reset Clk flag
flagDT=false; // Reset DT flag
// Update switch with 10ms debounce
testSW=(PIND>>SW)&1;
if (testSW!=statusSW) {
statusSW=testSW;
cntSW=10;
if (cntSW>0) {
cntSW--;
if (cntSW==0) {
Switch=statusSW;
UpdateSwitch=true;
/* MENU SET UP */
char* menuName[]={"Done ","Year ","Month ","Day ","Hour ","Minute ","Second ","Adjustment "};
int menuSize=sizeof(menuName)/sizeof(char*);
char menuValue[]= { 0, 0, 1, 1, 0, 0, 0, 0};
char menuNumeric[]= {'N','Y','Y','Y','Y','Y','Y', 'Y'};
char menuValueMin[]={ 0, 0, 1, 1, 0, 0, 0,-126};
char menuValueMax[]={ 1,126, 12, 31, 23, 59, 59, 126};
char menuLevel=0;
void setup() {
// Initialise rotary encoder and push button
pinMode(Clk,INPUT_PULLUP); // Rotary Clk
pinMode(DT,INPUT_PULLUP); // Rotary DT
pinMode(SW,INPUT_PULLUP); // Rotary SW
// Turn on polling ISR
OCR0B=0xA0;
TIMSK0|=1<<OCIE0B;
// Initialise LCD
pinMode(led,OUTPUT);
digitalWrite(led,HIGH);
lcd.begin(16,2);
lcd.print("Rotary Encoder");
delay(3000);
bool processMenu(void) {
static char lastPos=0;
static char lastMenuLevel=-1;
// Pre-empt menu level display
if (menuLevel!=lastMenuLevel) {
lastMenuLevel=menuLevel;
lcd.clear();
lcd.setCursor(0,0);
if (menuLevel==0) {
lcd.print("Menu:");
lcd.setCursor(0,1);
lcd.print(menuName[EncoderPos]);
if (menuNumeric[EncoderPos]=='Y') {
lcd.print((int)menuValue[EncoderPos]);
} else {
if (menuValue[EncoderPos]!=0) {
lcd.print("Y");
} else {
lcd.print("N");
} else if (menuLevel==1) {
lcd.print("Set:");
lcd.setCursor(0,1);
lcd.print(menuName[lastPos]);
if (menuNumeric[lastPos]=='Y') {
lcd.print((int)menuValue[lastPos]);
} else {
if (menuValue[lastPos]!=0) {
lcd.print("Y");
} else {
lcd.print("N");
} else {
lcd.print("Rotary Encoder?");
// If push button pushed toggle menuLevel
if (UpdateSwitch) {
UpdateSwitch=false;
if (Switch==LOW) {
// Re-enter menu if button pushed (for long enough)
if (menuLevel==-1) {
menuLevel=0; // Item menu
lastPos=1; // Trigger menu update
EncoderPos=0; // Done
menuValue[0]=0; // N
} else {
// Toggle menu level
menuLevel=1-menuLevel;
if (menuLevel==0) {
// Save item menu position
EncoderPos=lastPos;
// Exit menu if done!
if ((EncoderPos==0)&&(menuValue[EncoderPos]!=0)) menuLevel=-1;
} else {
// Set value for edit menu
EncoderPos=menuValue[lastPos];
// If encoder turned
if (menuLevel==0) { // Select menu item
if (lastPos!=EncoderPos) {
if (EncoderPos>=menuSize) EncoderPos=0;
if (EncoderPos<0) EncoderPos=menuSize-1;
lastPos=EncoderPos;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Menu:");
lcd.setCursor(0,1);
} else {
lcd.print("Y");
} else {
lcd.print("N");
} else if (menuLevel==1) { // Edit menu item value
if (menuValue[lastPos]!=EncoderPos) {
if (EncoderPos>menuValueMax[lastPos]) EncoderPos=menuValueMin[lastPos];
if (EncoderPos<menuValueMin[lastPos]) EncoderPos=menuValueMax[lastPos];
menuValue[lastPos]=EncoderPos;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set:");
lcd.setCursor(0,1);
} else {
lcd.print("Y");
} else {
lcd.print("N");
return (menuLevel!=-1); // Return true if menu active
void loop() {
if (!processMenu()) { // Menu not active
// Present the results
int i;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Running");
lcd.setCursor(0,1);
for (i=0;i<menuSize;i++) {
if (menuNumeric[i]=='Y') {
lcd.print((int)menuValue[i]);
} else {
if (menuValue[i]!=0) {
lcd.print("Y");
} else {
lcd.print("N");
lcd.print(" ");
delay(3000);
The main change was to pre-empt the menu level display. Previously it was only updated after the rotary button was turned or the push button pushed. Not very intuitive!
Pretty happy with the menu system now. Time to merge in the UT Clock code.
Magic
agp.cooper
Thanks! Great idea how to build user interface on a small display.
I try used this your code and it is working fine, except one thing - every other menu item is missing.
Doesn't matter how fast the encoder is turning. If I turn it long enough I eventually can access the missing menu items, but some times it takes over a minute.
I have thought it might be a bouncing but increasing cntSW didn't help.
Any ideas?
Michal
