Scale adjustment
A project log for Analog solar power meter
Using the Rpi, i've built a system that reads the data from my SMA inverter, and shows live output to an analog meter from the 30's.
sander-losSander Los • 02/20/2015 at 21:01•0 Comments
now the Meyer is up and running, it's time to do something about the scale... Made a photograph, edited it using the Gimp, printed it to fit over the original :) See the result:
