Here are the 2 pcb's I built (I was lucky and used my buddies CNC machine to make them). The reason I built 2 separate PCB'S is because the smaller one can be used for other projects ( I made 2 extra pcb's for another project). You can build all the stuff on one PCB if you like or point to point. I have the eagle files too if someone wants to have pcb's made or make the files better.
Parts is Parts (Notice my collection of EDT-49 Transformers CUE -EVIL LAUGH-)
PCB with SMPS and lm324 circuit.
PCB for 60HZ driver.
Backside view.
These are some STOUT Mosfets 100amp 500v and something like 2000 watts dissipation.
