As I noted in the previous log there are several elements in the upper case which converge to a single ribbon cable connecting the case to the logic board. At first glance this seemed daunting, however upon closer inspection I saw its a bit simpler.
After disassembling all of the pieces the breakdown is:
I spent a bit of time trying to see how can I interface with these parts and while researching the bluetooth module I came across a very helpful blog post by evilrobot: http://www.applefritter.com/node/23860
I'll sum up the post:
He talks about building a hackintosh with parts from a dead macbook and adds an important note: "in any iMac; MacBook; MBP; etc, etc - the Bluetooth module; keyboard and trackpad (on laptops); built in iSight; and IR Reciever are USB devices!!"
so final conclusions for now:
- The power button has a built in capacitor to delay its operation, thus it only works with voltage applied to it.
- Reed switch is coupled with a magnet in the LCD enclosure and needs power to work unlike simpler reed switches.
- bluetooth module, trackpad and keyboard are USB devices, which fits the 8 pins I saw going to the keyboard and trackpad controller.
- backlight interface still unknown. I'll test it soon enogh.
- The bluetooth module USB connection is not standard! it uses 3.3v instead of 5v! this means other internal usb connection need to be examined as well.
- hackintosh forums seem to be a good source of information.
Some notes regarding non upper case components:
- As mentioned iSight camera and IR receiver are also USB devices.
- I managed to use the front led (on the latch button) with a simple 3v battery, so I can simply use a GPIO connection to control it.
- WIFI antenna uses a ufl connector.
- The bluetooth module has a SPI interface which I assume is used to load firmware to the device.
