Slight change in the design of the bottom frame - was offered some 25x25mm box section for free so decided to go with that. I'll weld two lengths together along the rail sides so that there's enough room to mount the sbr rails.
The lengths are all cut to size, just need to clean up the ends and weld it together tomorrow.
koswix
