The next step was to check if i could use the existing transformer or if i needed to buy a new one.
The transformer had two primary windings rated for 115V connected in parallell, so all i had to do was to connected them in series to get a voltage drop of 230V instead of 115V.
The PCB had the possibility to do this by just moving a connector!
