Maxim's PIXI, 20-Port Programmable Mixed-Signal I/O with 12-Bit ADC, 12-Bit DAC, Analog Switches, and GPIO is now available with I2C interface instead of SPI.
PN is MAX11301.
I imagine data transfer will be much slower, but if you don't have the pins available, I2C is always a solution.
