Wow, another busy month gone past already! Plenty of time spent this month on the hardware revisions (Hoping to have these done by the end of Nov), but there was still a heap of work put into the firmware as well. As usual, here's a list of the main changes:
- Selectable ignition modes. In addition to the normal wasted spark mode output, you can now select either Single Channel (For use with distributor systems such as GM HEI) or Wasted COP (For <=4 cylinder only)
- High speed tooth logger is now working again and uses less memory
- rpmDOT added
- Basic launch control (With this comes the first implementation of the generic output code, more to come here)
- ConnerMcLaughlin's command line interface added (Thanks!)
- MAP sampling modes / windowing - Cycle average and cycle minimum are the most useful, but the old instantaneous mode remains (Mostly for testing)
- Multiple 'tooltip' style help comments were added into TunerStudio
I think that covers pretty much everything. November is going to be a lot more work on the hardware, but no doubt there will be lots happening on the firmware. I'm actually looking for suggestions for what people would like to see, so if there's been any features you want added, no is the time to call them out! No promises, but I'll see what I can do.
