The Design Specifications for this project are:
Must be charged from a micro USB plug.
Must deliver up to 2A.
Must be as small as possible.
Must be as cheap as possible.
Must boost the battery voltage to 5V.
Must be able to use most single celled LiIons.
Must have a charging LED.
I haven't included a battery protection circuit, as a lot of batteries come with them built it, for my drill cells, I bought a set of ten protection circuits off Ebay for a couple of pounds.
FrazzledBadger
ClimbinElectronics
Danie Conradie
mosaicmerc
Bud Bennett
Sorry I'm half asleep this morning, the 2A referred to the boost voltage output from the LiIon battery, not the charger.... Its been a while since I wrote the specifications and my memory is foggy nowadays...
