While waiting for my Spark Photon to arrive, I decided to code up using the Pro Mini as a stand in. I like to block out my code using comments, that way I can identify parts of code that need to exist and put them in the appropriate places. Not having any Formal schooling on code or code writing, I was just wondering if this is a "Thing"... comment coding, and if it's recommended, discouraged, etc. I know it works for me, but what do you PROs do?
////////////////////////Here there be loops////////////////////////
void loop() {
//Check for user interaction
//encoder button
AdminLoop();
//door reed switch
//alert parents
//Check for scheduled alarm status e.g. sleep time/wake time
//ChronoDot holds 2 alarms and will pull SQW pin low when alarm times are reached
//Check the time
//update the 7seg display
//update the Neopixel ring
void AdminLoop() {
//Administrative actions loops
//Loop to set time - Blue Encoder
boolean blnSetTime=true;
while (blnSetTime) {
//encoder button
blnSetTime=false;
//encoder spin
//Loop to set go to sleep - Red Encoder
//Loop to set wake up - Green Encoder
void Update7seg(String Time){
//put stuff into the 7seg display
void UpdateNeopixel(int Color, int NumLeds){
//paint up the Neopixel Ring
Junior
