I found this while browsing eBay:
https://www.sv1afn.com/ad8310fastrfd.html
"Measure LF to 440 MHZ with more than 90 dB of dynamic range and with the speed of a diode demodulator."
"With Ultra-Low-Noise 5V Voltage Regulator"
I should be getting one in about a week. It comes mostly assembled. NO SMD SOLDERING NEEDED!!! This should make this project much easier for others to duplicate.
