HMC784 - 10W RF SPDT Switch, LF to 4000 MHZ (4 GHZ), 30 dB Isolation, 15-40 nSec switching times, Very Low DC current - Good IMD3 (+60 dBm)
https://www.sv1afn.com/hmc784_trswitch.html
This uses the same chip as the eval board from DigiKey for $138.75 and includes a hex inverter for single wire control!
Plus, the DC blocking capacitors are unpopulated. So, you can select the best values for the frequency you are using. Here is a brief discussion on picking the best values for the caps.
Glenn Powers
