Seems to work pretty good so far, can charge the battery while using or run on battery alone. Currently setting up a script to email its current IP on the FONA so it can be dropped and act as a Pivot box.
A project log for Raspberry Pi Fona PiHat
All in one, plug in pi hat that includes a power converter, adafruit FONA, on a hackaday perma proto hat
