Reverse SSH running!
A project log for Raspberry Pi Fona PiHat
All in one, plug in pi hat that includes a power converter, adafruit FONA, on a hackaday perma proto hat
fhlipzerofhlipZero 03/02/2015 at 06:060 Comments
took lots of tinkering with ssh to get it to work but just got my reverse connection running! The Pi now boot, starts the FONA PPP connection, then does a reverse back to my local machine over the cell network. The command prompt is laggy as expected with the 2g data rate but its a worth while trade off. This Pi can now act as a pivot box or a remote recon box, next test will be to see the actual battery life with an active data connection, heres hoping the A+ pulls little enough that it lasts a good while!
Rich text editor
