Hackaday.io Hackaday.io
Sign up Log in
TinyESP ESP8266 Breadboard Adapter
TinyESP is a tiny size breadboard adapter for ESP-12/ESP-07 ESP8266 WiFi module. It contains a 3.3V voltage LDO, a Reset button and a flash
yancanyancan
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
434 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
239
2
434
14
Team (1)
  • yancanyancan
Join this project's team
  • TinyESP at Github
  • TinyESP at tindie
hardware
completed project
wifi ESP8266
Related lists
Awesome Projects on Tindie
Hackaday.io projects you can buy in the Tindie maker marketplace
This project was created on 02/28/2015 and last updated 12 years ago.
Description
ESP8266 is an inexpensive serial-to-wifi tranceiver chip that can be used to connect any microcontroller with a serial port to a WiFi network. Because of its simplicity and low cost, it is getting popular among hobbyists for building Internet of Things (IoT) applications.ESP-12 are very well featured ESP8266 modules that have all the I/O pins available to developers. ESP12 uses 2mm pitch edge castellation (half-via) connectors that are almost impossible to mount on a breadboard. The adapter is breadboard friendly.
Project Logs
Collapse
  • I made a USB to UART converter for TinyESP
    yancan • 03/12/2015 at 01:35 • 0 comments
    Plug TinyESP to the board and upgrade firmware. The chip is CP2102.
  • I sell on tindie now
    yancan • 02/28/2015 at 01:30 • 0 comments
    The link for TinyESP at tindie
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
josh.hulbert wrote 10/08/2015 at 14:55 • point
Really like these breakouts, I ordered a few on Tindie and got them within about a week to the US.  Relatively painless to assemble and they work very well for me!
RiRomain wrote 09/01/2015 at 12:14 • point
One of the best design I've seen for an ESP to breadboard adapter! They usually don't include reflash button/jumper or integrate to much functionality. By not soldering the esp but inter-calling a 2mm pin female header it will allow convenient module reflash.
Thanks for this :-)
NodeMCU brought a whole new paradigm to IoT -- using the Lua scripting language to built internet-connected apps with the ESP8266!
Project Owner Contributor
ESP8266 Lua Tutorials
alexanderAlexander
ESP32 Module with A CP2102 http://www.analoglamb.com/product/esp32-development-board/
ESP32 Development Board
abrahamAbraham
Easy place and remove flashing board for individual ESP12 (maybe other) WiFi boards.
ESP8266 - ESP 12 Flashing Board
nunyaNunya
Modular MCU Platform with decomposed Sections in a M.2 (22/30mm) Formfactor
SNAPZZ - Modular Microprocessor Platform
thorsten-jaegerThorsten Jaeger
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "TinyESP ESP8266 Breadboard Adapter", please tell us the reason.
Send message
Remove Member
