Over the weekend I got all of the diodes and keys soldered onto the PCBs, and connected all the PCBs together. There were a couple of small problems: one unconnected pad on the right thumb cluster (grrr!); and the left thumb cluster columns were swapped (so just incorrect silk screen). I also got the bottom plate of the case made and all the boards mounted. I just ordered key caps from Signature Plastics, and I still have to cut the openings in the top plate of the case.
