Considering replacing the HC-06 modules with ESP8266. The Bluetooth connection is extremely prone to failing. Even a slight change in the placement or orientation of the sender or receiver can cause a huge difference in reliability.
Also this change would get rid of the node.js middleman which is a huge bonus.
Harri Ohra-aho
