It's quite fast to make an HTTP API connected Pebble app using the pebble.js framework and the Cloudpebble browser IDE, so I made a dashboard app that provides a similar view into the measurement data as the web dashboard.
The app shows the current values for each sensor in a menu UI and each item can be drilled into for information on the previous measurement and the time of measurement.
Harri Ohra-aho
