Battery level/charging
A project log for Open source sport/smart watch
Make Weloop Tommy an open source sport watch that can connect directly to all kind of sensors (heart rate monitor and so on)
krzysiekKrzysiek • 03/17/2015 at 22:20•0 Comments
Weloop tommy uses bq24232 chip as a battery charger. Documentation for this chip can be found HERE.
There are only two pins that are interesting for us, one is a charging indicator which is high when an external power supply is connected. The second one is a battery level.
DescriptionNRF WLCSP ballNRF pin name
Battery levelH9P0.05
Battery charging indicatorC5P0.25
