Initial Prototype
A project log for Isothermal Calorimeter
This project is a Heat Conduction Isothermal Calorimeter based on the designs of Dr Lars Wadsö, Sweden.
ahmed-hefnawi-voltaAhmed Hefnawi (Volta) 03/17/2015 at 10:250 Comments
The prototype is complete now, I calibrated my sensors with water in the reference vial so this calibration coefficient will work with solution but I will have to re-calibrate it for cement.
The calibration for cement will require filling the reference (inert) vial with Sand or NaCl. Because the specific heat capacity for water is 4182 J/kg while Concrete is 880 J/kg which matches that of Salt and NaCl of 880 J/kg. Sand will be accessible in our Lab, and its specific heat capacity is 830 J/kg.
A PhD student at my faculty is using the device now to perform the heat of hydration of cement experiment over an interval of 7 days. The data is being logged to a micro SD card into a CSV file every 5 seconds (which can be opened via libreOffice Calc or any spreadsheet program).
I'll be adding more specific details about the build and the calibration process.
The cement sample vial being lowered into the vial holder inside the calorimeter.
Rich text editor
