My mirror arm modifications failed to clear the end effector pulleys. These things will happen now that I have the motion platform and the P1 split into projects, and re-used the same global variables in both, so I can't just import one into the other. Ooops.
I have moved the virtual pulleys up to their 'ideal' location on the same plane as the center of the pushrod gimbal.
![](https://cdn.hackaday.io/images/646511537146892124.png)
It's now half a gram heavier, but prints faster. Go figure.
Printing... again.
<EDIT> I needed 1mm more, but I'm not willing to modify the end effector any more to get it.
Moved the mounting point on the head. Printing that again..
</EDIT>
