Mirrors, check. Optics, nope.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
masterofnullMasterOfNull 02/01/2018 at 18:340 Comments
The acetone softened the coating enough to allow it to be removed.  I got about half way done before I realized I needed to be a bit more gentle with the bare silver though and ruined more than half of it.
Everything was looking good, until I held the resulting mirror up to the light and could see through it everywhere I had scratched.  The silver coating was very, very thin.  Just rubbing too hard would take it off.
So I ended up with one probably usable front surface mirror about 36mmx33mm and a good idea of how to do better next time.
Next was to assemble a mockup of my optics to see how it worked.  It doesn't.
The FOV of my endoscope camera was 67 degrees.  That was far too large of a beam, so the plan was to reduce that to 33.5 degrees with a 2:1 telephoto cell phone camera lens placed in the beam path directly after the first bounce.  This didn't work as I had hoped.
None of these issues are show stoppers, but they all add up to larger and heavier mirrors located farther away will be needed.  I was already near the limit of what I was willing to ask a 9g servo to do reliably.
If it starts to take longer than ~0.25 seconds to deploy and retract the mirrors, I might as well scrap this part of the plan and move to a dedicated up-looking camera.  At that point I can move the entire head/part being viewed to a stationary camera faster.  Simpler too..
