I made two more tube plates for experimental dekatron cell.
From left to right
- BCD-to-BIN coder unit
- 6-channel voltage stabilizer unit
- Dekatron unit with BIN-to-BCD coder and carry output
- [Required to build] Write amplifiers and level shifters unit
Now, 3U crate look like this. But I need to re-drill the rail holes to give the modules more space between each other. On the back, coolers, transformers and rectifiers would be added.
