this project started using an adafruit 3.5 tft which while useful when using scripted attacks was fun, was still limited and hard to use by the screen size. Adafruit kindly released the new Kippah tft driver board allowing larger screens to be used without the cumbersome hdmi cables needed by others.
This project now consists of a Pi 2, 4400mah battery from my fona pi, 7in tft, adafruit kippah, and adafruit powerboost.
Power is sent from the boost into the screen then the pi clips into the kippah keeping everything nice and neat. Also attached a power switch to the side of the boost.
Finally kali was installed and configured for the tft and kippah. There seems to be a bug in Kali where it has a gpio mapped that interferes with the kippah causing a blue hue over the screen. Nothing major just annoying
Case soon to come as this is hard to pocket without something catching :P
