Quick note to let you know that two different boards were submitted to OSH park. The first was the USB Storage Sled 4layer board. The second was a Dummy Intel Edison board (2 layers). The latter supplies 3.3V and 1.8Vs to the USB Storage Sled along with #RESET ... The idea is that cheap board would be used in place the Intel Edison Module; Allowing me to test the board using a standard pc/hub; rather than risking the Edison with wiring errors.
The Sled was submitted to OSHPark on March 13th. The Dummy board was submitted yesterday (3/17).
zittware
